Should I add 0 order when I stimulated diffract grating?
Posted 26 sept. 2023, 08:51 UTC−4 0 Replies
Today I stimulated diffract grating through by learning template, if I follow the case ,I can get the same reflect efficiency result picture; However, when I add 0 order under port one , the result changed a lot, so why cause it? and it is need add 0 order or isn't?
Hello 杰 刘
