Dave Greve
Certified Consultant
12 months ago
23 août 2023, 14:05 UTC−4
Updated:
12 months ago
The circular TE11 mode is not axially symmetric, so of course it cannot be modeled as 2D axisymmetric.
Robert Koslover
12 months ago
23 août 2023, 14:53 UTC−4
Updated:
12 months ago
Dave Greve is correct (of course) about the TE11 mode not being axially-symmetric. However, Comsol Multiphysics will support a rather clever combination of a 2D axi-symmetric model with an analytic assumption about the azimuthal dependence of the fields. You can learn all about this method from the supplied Application Library example at https://www.comsol.com/model/corrugated-circular-horn-antenna-15677 . I believe you should be able to adapt this approach to your problem. Good luck.
Dave Greve is correct (of course) about the TE11 mode not being axially-symmetric. However, Comsol Multiphysics will support a rather clever *combination* of a 2D axi-symmetric model with an *analytic* assumption about the azimuthal dependence of the fields. You can learn all about this method from the supplied Application Library example at https://www.comsol.com/model/corrugated-circular-horn-antenna-15677 . I believe you should be able to adapt this approach to your problem. Good luck.
12 months ago
23 août 2023, 16:43 UTC−4
Updated:
12 months ago
23 août 2023, 17:12 UTC−4
TICRA has a similar body of revolution (2D Axisymmetric) solver. They were probably aware that having the TEM will make the solver unusable so they provided the right option for port definitions.
The corrugated horn example does not address my problem.
12 months ago
23 août 2023, 16:45 UTC−4
Updated:
12 months ago
23 août 2023, 17:15 UTC−4
I did and COMSOL crashed. Had my equations checked by several people and found OK.
Robert Koslover
12 months ago
23 août 2023, 18:32 UTC−4
Updated:
12 months ago
23 août 2023, 18:31 UTC−4
Hmm. Not sure what caused it to crash. I've used the example method successfully, but it does take some attention to detail. Anyway, you might want to consider posting your .mph file to the forum or even contacting Comsol Support directly, since the Comsol folks are usually interested in fixing any condition that would tend to crash the software (that is, as opposed to simply generate an error message). Error messages (due to error causing conditions) are to be expected now and then; crashes are not.
