How enter relative permitivity of a material
How can I define relative permitivty of a material in comsol, if I knew real and imaginary parts of refrative index for a range of wavelenths in table form. plz help me.
1 Reply Last Post 20 août 2023, 16:44 UTC−4
Posted: 12 months ago 20 août 2023, 16:44 UTC−4
Updated: 12 months ago 20 août 2023, 16:47 UTC−4
You can specify the relative permittivity of a material under the material properties.
Component --> Materials --> etc. I suggest you consult the Comsol Multiphysics Help system and/or study the examples in the supplied Application Library, to see how this is done. If you have data in the form of a table, you may wish to import it and create an interpolation function to go with that data. You can then use that interpolation function in your specification of the material's permittivity.
You can specify the relative permittivity of a material under the material properties. Component --> Materials --> etc. I suggest you consult the Comsol Multiphysics Help system and/or study the examples in the supplied Application Library, to see how this is done. If you have data in the form of a table, you may wish to import it and create an interpolation function to go with that data. You can then use that interpolation function in your specification of the material's permittivity.
