phase dependent cuurent
hi all
how can i induce some phase dependent currents in comsol?
especially i wanna know how to make 3 currents with 120 degree different phase
5 Replies Last Post 11 nov. 2012, 09:09 UTC−5
Posted: 1 decade ago 10 nov. 2012, 04:16 UTC−5
COMSOL uses the "phasor approach so by using complex values for the amplitudes you can includ phase info to your frequency domain (harmonic) solver sweep analysis, check the doc, and I belive I have seen a model library of a 3 phse example, or was it on the model gallerie ?
It has alread ybeen discussed a few years ago, here on the Forum, the method is still the same ;)
Hi COMSOL uses the "phasor approach so by using complex values for the amplitudes you can includ phase info to your frequency domain (harmonic) solver sweep analysis, check the doc, and I belive I have seen a model library of a 3 phse example, or was it on the model gallerie ? It has alread ybeen discussed a few years ago, here on the Forum, the method is still the same ;) -- Good luck Ivar
Posted: 1 decade ago 10 nov. 2012, 06:51 UTC−5
thanks a lot for your answer ivar
may i ask from you to put the link you mentioned? i couldnt find it.
thanks a lot for your answer ivar may i ask from you to put the link you mentioned? i couldnt find it.
Posted: 1 decade ago 10 nov. 2012, 07:11 UTC−5
try a search on the Forum with PHASOR, and do the same on the help of COMSOL, and/or the PDF doc of the general user manual and the ACDC one
Hi try a search on the Forum with PHASOR, and do the same on the help of COMSOL, and/or the PDF doc of the general user manual and the ACDC one -- Good luck Ivar
Posted: 1 decade ago 10 nov. 2012, 11:50 UTC−5
thanks for your quick answer.
I found this link and it appears it would be useful but I use COMSOL 4.1 and this model has been written by a higher version so I cant load it. is it possible to open that? what should I do?
thanks in advanced
thanks for your quick answer. I found this link and it appears it would be useful but I use COMSOL 4.1 and this model has been written by a higher version so I cant load it. is it possible to open that? what should I do? thanks in advanced
Posted: 1 decade ago 11 nov. 2012, 09:09 UTC−5
link: www.comsol.com/community/forums/general/download/file/9293/Stator_3phase.mph
link: http://www.comsol.com/community/forums/general/download/file/9293/Stator_3phase.mph
