How to read an error and find the corresponding variable
Posted 25 juil. 2023, 14:17 UTC−4 Fluid & Heat, Chemical Reaction Engineering, Physics Interfaces Version 6.1 0 Replies
I get the below error and I wonder if you can help me to understand the error and find the corresponding varible/interface.
I use heat(solid+fluid)+flow+moving mesh+chemistry+transport of concentrated species(TCS) interfaces+Thermodynamics under global defenitions and using multiphysics reacting flow interface (not nonisothermal flow multiphysics interface)
The following feature has encountered a problem: - Feature: Stationary Solver 2 (sol6/s2) Velocity u, Pressure p Failed to evaluate Jacobian of operator. - Operator: laginterpdiff - Geometry: geom1 - Domain: 18 Failed to evaluate Jacobian of expression. - Expression: dvol_spatial(((comp1.spf.res_p(comp1.nirf1.tau_c(-nojac((comp1.nirf1.rhocomp1.spf.betaT)(comp1.u-d(x,TIME))))))-(comp1.spf.res_u(nojac(comp1.nirf1.rho)comp1.nirf1.tau_m)))-(comp1.ht2.res_T(comp1.ht2.tau_enojac((comp1.nirf1.rhocomp1.ht2.alphap)((-comp1.u)+d(x,TIME)))))) Failed to evaluate Jacobian of expression. - Expression: (comp1.nirf1.streamlinenitf)(dvol_spatial)
Thank you
Hello Hooman Enayati
