where can i find the error message in the help documents of comsol4.1?
Dear all,
An error occured saying that undefined value found!
where can i find the relevant explanation for this error?
Regards
Song
3 Replies Last Post 5 juin 2014, 11:45 UTC−4
Posted: 1 decade ago 6 nov. 2012, 00:43 UTC−5
there is from my knowledge no long list (yet in v4) but normally it tells you which variable is undefined, often its a material parameter missing, and you need to search therearound
Hi there is from my knowledge no long list (yet in v4) but normally it tells you which variable is undefined, often its a material parameter missing, and you need to search therearound -- Good luck Ivar
Posted: 1 decade ago 6 nov. 2012, 02:33 UTC−5
Dear Ivar,
Thanks a lot for your reply.
I will try this out.
song
Dear Ivar, Thanks a lot for your reply. I will try this out. song [QUOTE] Hi there is from my knowledge no long list (yet in v4) but normally it tells you which variable is undefined, often its a material parameter missing, and you need to search therearound -- Good luck Ivar [/QUOTE]
Posted: 1 decade ago 5 juin 2014, 11:45 UTC−4
This is because you have not choose all the variables in the Segregated steps.
Wenjia
Hi, This is because you have not choose all the variables in the Segregated steps. Good luck Wenjia
