Select and hide
Howdy folks,
I am wondering if there is way to select and hide in the explict definitions
For instance, we define a explicit definitions and we would like to select specific domains, and we also want those selected domains are hidden after selected. Is there a way to do that?
8 Replies Last Post 2 août 2023, 16:14 UTC−4
Diotima University of Manchester/Material Science
Posted: 2 years ago 19 juil. 2023, 03:51 UTC−4
Updated: 2 years ago 19 juil. 2023, 03:52 UTC−4
you can directly hide or show geometry by seleting "Hide" or "Show" in this section,
I'm the loser student who really want a PHD placement.
Posted: 2 years ago 19 juil. 2023, 16:00 UTC−4
Hi, Diotima
Thanks for the reply. I know this function, but what I am running into a problem is that: suppose you are trying add domains into some boolean operations, and you don't want to see them after they are added. Is there a way to do that?
Anyway, thanks for the help.
Hi, Diotima Thanks for the reply. I know this function, but what I am running into a problem is that: suppose you are trying add domains into some boolean operations, and you don't want to see them after they are added. Is there a way to do that? Anyway, thanks for the help.
Posted: 2 years ago 20 juil. 2023, 05:24 UTC−4
As they each have a number, you could perhaps keep a list of these numbers and copy them into your selection windows.
René Christensen, PhD
Acculution ApS
www.acculution.com
info@acculution.com
Posted: 2 years ago 20 juil. 2023, 15:49 UTC−4
Hi, Acculution
Thanks. This is very helpful suggestions, would you mind pointing out how to get a list of hided domains?
Appreciate!!
Hi, Acculution Thanks. This is very helpful suggestions, would you mind pointing out how to get a list of hided domains? Appreciate!!
Posted: 2 years ago 31 juil. 2023, 12:53 UTC−4
Hi, Acculution
Appreciate!!
I would probably just make a dummy phyiscs and select the domains in question They will be blue so I can see what I have selected Then make an explicit selection and delete the dummy physics
Acculution ApS
www.acculution.com
info@acculution.com
>Hi, Acculution > >Thanks. This is very helpful suggestions, would you mind pointing out how to get a list of hided domains? > >Appreciate!! I would probably just make a dummy phyiscs and select the domains in question They will be blue so I can see what I have selected Then make an explicit selection and delete the dummy physics
Posted: 2 years ago 1 août 2023, 13:22 UTC−4
Hi, Acculution
Yeah, this is a very clever trick. Thanks for the input.
Hi, Acculution Yeah, this is a very clever trick. Thanks for the input.
Walter Frei COMSOL Employee
Posted: 2 years ago 1 août 2023, 13:43 UTC−4
Note also that you can have multiple of the: Component > Definitions > View > Hide for Physics features Within that feature, you can select via any predefined Selection set.
One approach is to define a number of different Explicit Selections, and then create (and appropriately name) one "Hide for Physics" for each selection.
As a last step, you can enable/disable the individual "Hide for Physics" features. (Which should be easy once you've named them appropriately.)
Hello, Note also that you can have multiple of the: Component > Definitions > View > Hide for Physics features Within that feature, you can select via any predefined Selection set. One approach is to define a number of different Explicit Selections, and then create (and appropriately name) one "Hide for Physics" for each selection. As a last step, you can enable/disable the individual "Hide for Physics" features. (Which should be easy once you've named them appropriately.)
Posted: 2 years ago 2 août 2023, 16:14 UTC−4
Updated: 2 years ago 2 août 2023, 16:26 UTC−4
Hi, Frei
Thank you! I will implement your suggetions next time.
Hi, Frei Thank you! I will implement your suggetions next time.
