help me to find how to get exact values from model
Dear all ,
I simulated two coil system in induction coupling , and i define parameters and formulas in parameters section , but i dont know how to derive practical values by applying same formula in model , can you please help to get Mutual inductance and field intensity and flux density values
Thanks in advance
Model attached
kishore Naik Mude
1 Reply Last Post 31 oct. 2012, 13:00 UTC−4
Posted: 1 decade ago 31 oct. 2012, 13:00 UTC−4
HI, Kishore,
Your model is very similar to:
www.comsol.com/showroom/documentation/model/12687/
("Mutual Inductance and Induced Currents in a Multi-Turn Coil").
I suggest you to take a look at it.
If you try the mutual inductance in open loop (secondary at 0[A]) you'll get
(8.67347e-6-5.19325e-10i) H from the expression: mf.VCoil_2/(mf.iomega*1[A])
(notice that I have set the primary coil to current feed of 1[A]).
Jesus.
HI, Kishore, Your model is very similar to: http://www.comsol.com/showroom/documentation/model/12687/ ("Mutual Inductance and Induced Currents in a Multi-Turn Coil"). I suggest you to take a look at it. If you try the mutual inductance in open loop (secondary at 0[A]) you'll get (8.67347e-6-5.19325e-10i) H from the expression: mf.VCoil_2/(mf.iomega*1[A]) (notice that I have set the primary coil to current feed of 1[A]). Jesus.
