Export and import explicit selections
Hii
is it possible to export explicit selections together with the geometry? When I import the geometry into a new model after adding physics I can only select Object 1 (import 1), Object 2 (import 1), ... etc and not the created explcit selections from the previous model.
Thank you!
1 Reply Last Post 7 juin 2023, 07:46 UTC−4
Magnus Ringh COMSOL Employee
Posted: 1 year ago 7 juin 2023, 07:46 UTC−4
If you save the original model as an MPH file and then use Insert Sequence from the Geometry node's context menu to insert the geometry sequence from the saved MPH file, the explicit selections should be included.
Magnus
Hi, If you save the original model as an MPH file and then use **Insert Sequence** from the **Geometry** node's context menu to insert the geometry sequence from the saved MPH file, the explicit selections should be included. Best regards, Magnus
