torque calculation under the air flow
I hope this text finds everyone of you well. I am reaching out to request your guidance in performing a CFD analysis of a 2 bladed helical vertical axis wind turbine in COMSOL. I believe you would be able to provide me with the guidance I need to successfully complete this project.
I am currently working on a research project which requires the analysis of the flow field around a vertical axis wind turbine.i created the 3D CAD model using solidworks and it is perfect .My aim is to investigate the effects of various parameters on its performance and to calculate the torque of turbine under the turbulent air flow of 5m/s. but i didnot find any tutorial or blog related to this thats why its very complicated for me.
I am hoping that anyone of you would be able to provide me with some guidance and direction in setting up the simulation and torque calculation of vertical axis wind turbine under the airflow
Thank you for your time and consideration.
muddaser ahmed
0 Replies Last Post 5 juin 2023, 17:02 UTC−4
Hello Muddaser Ahmed Khan
