General extrusion of field from parametric sweep
Posted 23 mai 2023, 03:42 UTC−4 0 Replies
Hello everyone,
I am facing a problem with the general extrusion operator : I want to use it in order to repeat a potential field in space, because my geometry is periodic exactly the same way as suggested in this blog post : https://www.comsol.fr/blogs/using-general-extrusion-operators-to-model-periodic-structures/
It worked very well for a solution from a static study, but when I repeat my stationnary step in a parametric sweep (even without geometry modification) and when I call the extruded field in graphics (from the parametric solution), it is displayed only in one geometric period.
I do not receive any error message from the software so may be the extrusion is still working well and it is a problem of graphs ?
I already tried to force displaying for one parametric solution in particular with the withsol operator but the problem is the same : the extruded field is not displayed entirely (only in one geometry unit).
Thanks for help by advance
Nicolas
Hello Nicolas Ruyssen
