Robert Koslover
Certified Consultant
2 years ago
16 mai 2023, 18:27 UTC−4
Updated:
2 years ago
This is an electrostatics problem and there are a number of ways to address it. Some of the example electrostatics models available to you in the Application Library should be worth looking at. If you are a new user, see also: https://www.comsol.com/learning-center .
You may want to set floating potentials on your plate and cylinder -- you can find some discussions about how to do that, if you search this forum.
You may want to set *floating potentials* on your plate and cylinder -- you can find some discussions about how to do that, if you search this forum.
1 year ago
5 juin 2023, 02:40 UTC−4
Thank you sir ,
When adding a floating potential, the amount of charge required for a dielectric glass material depends on various factors such as the size and geometry of the glass, the desired potential, and the specific properties of the glass.
Thank you sir ,
Robert Koslover
1 year ago
6 juin 2023, 09:24 UTC−4
It would seem that I incorrectly assumed you were talking about conducting plates and cylinders, since you did not initially mention dielectrics. If you are talking about glass or other insulating materials, then these do not impose constant potentials upon their boundaries, so one would generally not assign any floating potentials there. In most such cases, one would simply assign appropriate material properties to the dielectric, mesh these parts along with the rest of the computational domain, and not assign specific boundary conditions to the insulators at all, unless you also mean to give them a non-zero net charge or perhaps model some kind of atypical or additional physics.
It would seem that I incorrectly assumed you were talking about *conducting* plates and cylinders, since you did not initially mention dielectrics. If you are talking about glass or other insulating materials, then these do not impose constant potentials upon their boundaries, so one would generally not assign any floating potentials there. In most such cases, one would simply assign appropriate material properties to the dielectric, mesh these parts along with the rest of the computational domain, and not assign specific boundary conditions to the insulators at all, unless you also mean to give them a non-zero net charge or perhaps model some kind of atypical or additional physics.
