Thermoelectric Effect
I'm working on Thermoelectric Generator and I would like to have a basic model with the equations used in COMSOL, Could anyone who worked in this field, please help.
With Regards .
Pheba
3 Replies Last Post 17 juin 2013, 14:09 UTC−4
Posted: 1 decade ago 22 oct. 2012, 01:22 UTC−4
have you checked the model builder pdf doc ?
Hi have you checked the model builder pdf doc ? -- Good luck Ivar
Posted: 1 decade ago 13 juin 2013, 14:30 UTC−4
I have. I went ahead and built a Thermoelectric node but I am still having difficulties. One error I noticed was that you may not have a a temperature and electric potential boundary on the same surface. I was wondering if there is anything already built to compare?
Thanks in Advanced,
Gaston Piller
Hello, I have. I went ahead and built a Thermoelectric node but I am still having difficulties. One error I noticed was that you may not have a a temperature and electric potential boundary on the same surface. I was wondering if there is anything already built to compare? Thanks in Advanced, Gaston Piller
Posted: 1 decade ago 17 juin 2013, 14:09 UTC−4
I actually was able to solve the issue on the boundary conditions--it ws due to a boundary override rule.
I did however, notice that if you reverse the conditions, ie, state temperature boundary conditions, and allow for COMSOL to provide a Voltage value, the results do not match.
I actually was able to solve the issue on the boundary conditions--it ws due to a boundary override rule. I did however, notice that if you reverse the conditions, ie, state temperature boundary conditions, and allow for COMSOL to provide a Voltage value, the results do not match.
