dynamic viscosity of a solid??
Prudhvi VVR Ajay Sreenivas
what value should I give for dynamic viscosity of a piezoelectric material??
1 Reply Last Post 27 mars 2023, 10:42 UTC−4
Posted: 2 years ago 27 mars 2023, 10:42 UTC−4
Updated: 2 years ago 27 mars 2023, 11:35 UTC−4
Hello Prudhi,
You should not assign a dynamic viscosity to a solid. If it looks like the software is asking for one, it's a sure sign that you forgot to remove the part of the geometry occupied by the piezoelectric material from the domains where the fluid equation is to be solved.
Jeff Hiller
Hello Prudhi, You should not assign a dynamic viscosity to a solid. If it looks like the software is asking for one, it's a sure sign that you forgot to remove the part of the geometry occupied by the piezoelectric material from the domains where the fluid equation is to be solved. Best, Jeff
