Buckling Analysis in Plate
Hi, I want to find the critical load of a plate with simply supported boundary conditions. And compare with analytical results. But I did not get the correct value. You can see further detail in the screenshot(Buckling_Plate_SSSS.png). The comsol file is also attached. Kindly tell me how I can fix this error.
Best, Rauf
1 Reply Last Post 27 mars 2023, 11:31 UTC−4
Posted: 2 years ago 27 mars 2023, 11:31 UTC−4
Plot the stresses (for example principal stress vectors) from the preload case to check your boundary conditions. You will, most certainly, spot the problem there.
Henrik Sönnerlind
COMSOL
