Gunnar Andersson
COMSOL Employee
2 years ago
22 mars 2023, 08:39 UTC−4
Updated:
2 years ago
You can do this using evaluation groups:
Create an evaluation group that contains two surface integrations.
The Transformation section in the evaluation group contains a Transformation type drop-down list. Choose General in the list. Set Expression to int1/int2 (the tags of the integration features).
Evaluate: The result is the element-wise ratio between the integrals in the two surfaces integrations.
* Create an evaluation group that contains two surface integrations.
* The **Transformation** section in the evaluation group contains a **Transformation type** drop-down list. Choose **General** in the list. Set **Expression** to int1/int2 (the tags of the integration features).
* Evaluate: The result is the element-wise ratio between the integrals in the two surfaces integrations.
Dave Greve
Certified Consultant
2 years ago
22 mars 2023, 11:56 UTC−4
Interesting, I did not know about this. Learn something every day.
Another (more obscure) way to do this is to define two integration coupling variables, and do a global evaluation of the ratio.
Hendrik
Mechanical Engineering
2 years ago
23 mars 2023, 06:32 UTC−4
Hello Gunnar,
Thanks for your helpful reply! It works like a charm.
Hello Gunnar,
