Partial cut plane
Posted 10 oct. 2012, 05:15 UTC−4 2 Replies
1) I have a 3D geometry. It is a pipe and I would like to do 2D cut plane. In my case I want to do partially. It means that I do not want to cut for all diameter (between boundaries) of pipe but for example 1/3 of diameter. Actually I need to take maximum velocity from desired area of pipe. Is it possible somehow? If not is it possible to add a function that will take maximum velocity from desired area?
2) I want also to change angle of cut plane by +/- 5 degrees. Can anybody explain me the plane entry method: point and normal? Is it a point and a perpendicular normal vector to the cutting plain? Am I right?
Thanks in advance.
Thanks in advance.
2 Replies Last Post 11 oct. 2012, 09:57 UTC−4
