Multi-pass continuous laser beam scan
Hi ,
i have one basic question about Multi-pass continuous laser beam scan . i have moved laser beam (Gaussian)with same velocity in y-direction on plate from one end to other end. it was taking 3 sec. then, i want to move heat source from (3.2 sec) original position. Is this possible in comsol GUI? or We should use any script language?
can we use any function to obtain the second time scan?
i used the following heat source for first scan
500[MW/m^3]*an1(sys2.r[1/m])
6 Replies Last Post 2 août 2016, 05:28 UTC−4
Posted: 1 decade ago 4 oct. 2012, 07:57 UTC−4
how do you scan w.r.t. to time ? there were a few threads already discussing raster scanning and functions to provide the trajectories ;)
Do not forget that you make discontinuities when you make sudden jumps, this gives some issues often for the solver to converge
Hi how do you scan w.r.t. to time ? there were a few threads already discussing raster scanning and functions to provide the trajectories ;) Do not forget that you make discontinuities when you make sudden jumps, this gives some issues often for the solver to converge -- Good luck Ivar
Posted: 1 decade ago 4 oct. 2012, 08:20 UTC−4
Hi ivar,
thank you for your quick reply. i want to move laser beam w.r.t time. i have used (V*t) this expression. V-is a speed of laser beam. i have used cylinderical co-ordinates to movement.but , i could not get the second pass.
How can i get second pass?
then,i want to move the spot w.r.t time and space?
how can acheive?
can you give any example (time and space dependent)?
sorry for the lot of questions
thank you ivar...
Hi ivar, thank you for your quick reply. i want to move laser beam w.r.t time. i have used (V*t) this expression. V-is a speed of laser beam. i have used cylinderical co-ordinates to movement.but , i could not get the second pass. How can i get second pass? then,i want to move the spot w.r.t time and space? how can acheive? can you give any example (time and space dependent)? sorry for the lot of questions thank you ivar...
Posted: 1 decade ago 4 oct. 2012, 12:45 UTC−4
define to different functions, one for each type of movement. Then combine them through boolean operators: f1*(t<t1)+f2*(t>t2)
define to different functions, one for each type of movement. Then combine them through boolean operators: f1*(tt2)
Posted: 1 decade ago 5 oct. 2012, 02:45 UTC−4
Hi Alex,
thank you for your response. but i could not understand. can you explain more....where can i find boolean operator..
i want to pass the (moving heat flux) beam 3 times in same path.can i use boolean operator..
can you help me?
Hi Alex, thank you for your response. but i could not understand. can you explain more....where can i find boolean operator.. i want to pass the (moving heat flux) beam 3 times in same path.can i use boolean operator.. can you help me?
Posted: 9 years ago 24 juin 2016, 03:49 UTC−4
Mr. Alexander
thanks a lot. Your reply really helped a lot.
Ashish Mishra
Mr. Alexander thanks a lot. Your reply really helped a lot. Ashish Mishra
Posted: 9 years ago 2 août 2016, 05:28 UTC−4
Hi Ivar,
While modeling, I am getting some relative residual error(singularity error) because of the discontinuity in time domain. Could you tell me how to make it smooth ?
Thank you.
[QUOTE] Hi how do you scan w.r.t. to time ? there were a few threads already discussing raster scanning and functions to provide the trajectories ;) Do not forget that you make discontinuities when you make sudden jumps, this gives some issues often for the solver to converge -- Good luck Ivar [/QUOTE] Hi Ivar, While modeling, I am getting some relative residual error(singularity error) because of the discontinuity in time domain. Could you tell me how to make it smooth ? Thank you.
