Monitoring multiple convergence plots (or probes) in cluster sweep (distribute parametric sweep)
Posted 5 févr. 2023, 21:34 UTC−5 Cluster & Cloud Computing, Studies & Solvers Version 5.6 0 Replies
Hello, I'm COMSOL newbie working on cluster computing.
I'm using distributed parametric sweep mode, in which each server node solves a single problem (ex. Node 1 - Inlet fluid velocity 1m/s, Node 2 - Inlet fluid velocity 2m/s etc...)
In distributed parametric sweep mode, (1) I want to monitor multiple convergence plots since multiple problems are solving simultaneously. But I can only monitor a single convergence plot... Please give me an advice.
(2) How can I monitor multiple probe plots (which is Probe parameter - Iteration number plots)? I can only monitor accumulated probe table, which is the final converged value. But I want to check the probe value trend with respect to iteration number.
Thank you very much!!! Every comment is my energy please help me!
Hello Young Jin Lee
