URGENT : Time dependent simulation
Posted 1 oct. 2012, 09:41 UTC−4 Structural Mechanics Version 4.2 0 Replies
I am trying to model an energy harvester in which discrete pressures must be applied one after the other. The pressure applied is not continuous but varying values of pressure is applied one after the other in short succession.
On the whole , a varying values of pressure are applied to the energy harvester and it must produce varying values of voltage continuously , as long as pressure is applied.
I found that even 'Time Dependent' study does not give a provision to model such a situation. It would be of great help if you can guide me through the steps involved.
Thanking you in advance,
Vijay
Hello Vijay Ramakrishnan
