Thermoelectric PDE mode
Posted 28 sept. 2012, 04:21 UTC−4 Heat Transfer & Phase Change, Modeling Tools & Definitions, Parameters, Variables, & Functions Version 4.2a 1 Reply
Hello Sir,
I am a new user of COMSOL. Currently I'm working on a model for a thermoelectric generator using PDE mode. After done with the layout, in the post processing result the temperature profile seems appropriate but I can't seem to obtain the right distribution for the voltage. When I did modifications on the dimension size or increase the N pairs, I get the same results as if no modifications have been made.
Therefore I have decided to use the custom physics interfaces as per attach files. However we still facing problems with some of the features. For example under Physics Interface 1 (UM_megat), Feature 1, 2, and 4, the COMSOL pop up message state that there are errors in syntax we used. Appreciate if you could review the file. We really need your help or suggestions to solve this error.
I am also not sure on how to specify the electrical and temperature boundary conditions correctly. If you have any working modules, appreciate if you could send to me.
Thank you.
Best Regards,
Megat
Hello Megat Muhammad Ikhsan Megat Hasnan
