Volume cavity
Hello
I am trying to calcuate volume cavity. I have a model with enclosed space on 2D axial symmety component. I assigned parapmetric sweep to increase pressure in the space. The pressress are 0, 20, 360 psi. I assigned definations " Areaint(-z*solid.nz)" on the boundaries in the space.
By using global evaluations, I got the volumes of the three different pressures. However, all the volume values are the same as the initial volume without pressure applied.
How can I get the correct volumes for the three different pressures.?
2 Replies Last Post 12 janv. 2023, 13:05 UTC−5
Posted: 2 years ago 12 janv. 2023, 09:05 UTC−5
In order to do this kind of evaluation, you must use a geometrically nonlinear analysis. If not, there is no difference between the undeformed Z and the deformed z.
As an alternative, you could write Areaint(-(Z+w)*solid.nZ). It will give an approximative value, since only the coordinate, but not the normal direction is updated. Thus, it will work reasonably as long as rotations are small.
Henrik Sönnerlind
COMSOL
In order to do this kind of evaluation, you must use a geometrically nonlinear analysis. If not, there is no difference between the undeformed Z and the deformed z. As an alternative, you could write Areaint(-(Z+w)\*solid.nZ). It will give an approximative value, since only the coordinate, but not the normal direction is updated. Thus, it will work reasonably as long as rotations are small.
Posted: 2 years ago 12 janv. 2023, 13:05 UTC−5
Updated: 2 years ago 5 févr. 2023, 12:27 UTC−5
Hello Henrik
Areaint(-(Z+w)solid.nZ) works ! Thank you so much. And I also tried "geometrically nonlinear analysis". I could get different volume values for the different pressures. However, the displacements for the analysis were significantly differnt from "linear anaylysis"
In this case, I don't know what anaylsis is giving me the correct results. Would you mind letting me know about what to do with "geometrically nonlinear analysis". ? I just simply checked "Include geometic nonlinearity". According to this link below.
I attached my file.
https://www.comsol.com/blogs/what-is-geometric-nonlinearity/
Hello Henrik Areaint(-(Z+w)solid.nZ) works ! Thank you so much. And I also tried "geometrically nonlinear analysis". I could get different volume values for the different pressures. However, the displacements for the analysis were significantly differnt from "linear anaylysis" In this case, I don't know what anaylsis is giving me the correct results. Would you mind letting me know about what to do with "geometrically nonlinear analysis". ? I just simply checked "Include geometic nonlinearity". According to this link below. I attached my file. https://www.comsol.com/blogs/what-is-geometric-nonlinearity/
