Changing the Ambient Temperature With Time
Is there a way to make the ambient temperature of a fluid(air) depend on time? I have used a function using an expression. While the expression plots correctly, it does not work as an initial condition. (Only takes t=0 as the initial condition) Is there a way to incorporate the changing ambient temperature to the model? (I am modelling the temperature and humidity around greenery throughout the day)
Thanks in advance.
1 Reply Last Post 10 janv. 2023, 03:38 UTC−5
Posted: 2 years ago 10 janv. 2023, 03:38 UTC−5
I found this post,
https://www.comsol.com/forum/thread/14509/Interpolated-variable-as-initial-value-for-time-dependent-eqn
which is the question I am having too. But did not understand the answer correctly.
If anyone can help, huge help :)
I found this post, https://www.comsol.com/forum/thread/14509/Interpolated-variable-as-initial-value-for-time-dependent-eqn which is the question I am having too. But did not understand the answer correctly. If anyone can help, huge help :)
