Failed to find a solution for the initial parameter.
Hi guys! I am trying to solve a electrical behaviour for different laters of material problem. Right now there is some problems with the resistivity and permeability in current LE and Current DE, however I think the values I have put in are accurate. I have tried to only use current SC and current AT layers and the model works fine. The COMSOL direct solver gave the following error:
Failed to find a solution for the initial parameter. The relative error (4.1e+002) is greater than the relative tolerance. Returned solution is not converged. - Feature: Stationary Solver 1 (sol1/s1)
Do you think it is a solver setting issue? Really appreaciate it!
0 Replies Last Post 5 déc. 2022, 07:34 UTC−5
Hello Miles Su
