Sensitivity Plotting
When modeling a pressure sensor how can I create a plot that shows the subsequent sensitivity of the device in terms of: Voltage (V) /unit pressure (kPa).
1 Reply Last Post 16 sept. 2012, 02:42 UTC−4
Posted: 1 decade ago 16 sept. 2012, 02:42 UTC−4
I would propose that you run a continuation sweep solver case with increasing pressure and then use the derived Variable postprocessing nodes to define the average voltage per pressure value, you get a table output that you might get also as a graph, with a click on the graph icone
Hi I would propose that you run a continuation sweep solver case with increasing pressure and then use the derived Variable postprocessing nodes to define the average voltage per pressure value, you get a table output that you might get also as a graph, with a click on the graph icone -- Good luck Ivar
