After modifying the material parameters, the model is wrong
Posted 1 nov. 2022, 05:05 UTC−4 Version 6.0 0 Replies
Hello, I'm using a dynamic mesh to study the fluid-structure interaction of fractures.In the beginning, I used the wrong material properties to get the results.However, after I modified the material parameters, the model calculation was wrong, I don't know how to solve the problem. Will you help me out?The initial fluid viscosity is 17,After modification, is the viscosity of water.And the flow patterns have not changed.
Hello 建雷 黄
