Time dependant heat flux at the boundary
I am trying to model 3D tissue. I wish to apply a time-dependent heat flux for one boundary. I have introduced an interpolation function under global definition. Basically, the function is a sin wave,i.e., f(t)=sin(wt). I am getting a smooth plot of the sine wave. The problem is that, I am unable to figure out the way to implement that heat flux to behave like a sin wave.
Thanking You
Arka
11 Replies Last Post 5 nov. 2016, 17:34 UTC−4
Posted: 1 decade ago 15 sept. 2012, 05:20 UTC−4
I do not really understand what you are missing, if you have a boundary heat flux condition and you write
P0[W/m^2]*sin(omega[1/s]*t) with a time dependent solver and omega some frequency value then you should see your system being influenced by the sinus excitation.
But do not forget that a time series solver is a transient type analysis, normally for a few periods, if you are interested in the steady state sinus exciatiaion response you should rather consider the frequency domain solvers (harmonic developments of the equations, see the Equation view
Hi I do not really understand what you are missing, if you have a boundary heat flux condition and you write P0[W/m^2]*sin(omega[1/s]*t) with a time dependent solver and omega some frequency value then you should see your system being influenced by the sinus excitation. But do not forget that a time series solver is a transient type analysis, normally for a few periods, if you are interested in the steady state sinus exciatiaion response you should rather consider the frequency domain solvers (harmonic developments of the equations, see the Equation view -- Good luck Ivar
Posted: 1 decade ago 15 sept. 2012, 05:53 UTC−4
Thank you Mr. Ivar
Actually I understand that the problem was with unit. I have considered omega a constant and comsol understand time,t in sec. But inside Sin function t should be [1/s], and that solves problem. Now it is working fine.
Kind Regards
Arka
Thank you Mr. Ivar Actually I understand that the problem was with unit. I have considered omega a constant and comsol understand time,t in sec. But inside Sin function t should be [1/s], and that solves problem. Now it is working fine. Kind Regards Arka
Posted: 1 decade ago 15 sept. 2012, 16:32 UTC−4
It's always useful to check the units, as "t" is in seconds you can either write omega[1]*t[1/s] or omega[1/s]*t to get a unitless call for sinus(), but do not forget an orange unit "error" is a warning, COMSOl calculate anyhow, while red is an error and COMSOL will flag it and halt
Hi It's always useful to check the units, as "t" is in seconds you can either write omega[1]*t[1/s] or omega[1/s]*t to get a unitless call for sinus(), but do not forget an orange unit "error" is a warning, COMSOl calculate anyhow, while red is an error and COMSOL will flag it and halt -- Good luck Ivar
Posted: 1 decade ago 17 sept. 2012, 05:44 UTC−4
Hello Sir,
I have another query. Regarding the temperature profile? Since I am irradiating the boundary using a sin wave. So, I am assuming that the temperature profile at the irradiated boundary should behave a similar nature like a wave. But I am getting temperature curve at a point on the boundary straight lines. It is not following a sin nature. I am using time step of 0.1 for time marching procedure. But I think the temperature profile is not taking all the time steps it is skipping certain points. It is showing irregular straight lines like it has skipped few points. I am not sure what is the problem.
Thanking You
Arka
Hello Sir, I have another query. Regarding the temperature profile? Since I am irradiating the boundary using a sin wave. So, I am assuming that the temperature profile at the irradiated boundary should behave a similar nature like a wave. But I am getting temperature curve at a point on the boundary straight lines. It is not following a sin nature. I am using time step of 0.1 for time marching procedure. But I think the temperature profile is not taking all the time steps it is skipping certain points. It is showing irregular straight lines like it has skipped few points. I am not sure what is the problem. Thanking You Arka
Posted: 1 decade ago 17 sept. 2012, 09:10 UTC−4
indeed it looks like the time stepping is being too coarse, the thing is that by default COMSOL assumes a diffusion type model decay, so when you have a periodic BC you must tweak a little the time stepping settings.
Use rather an intermediate or a strict time stepping (and not the default automatic for periodic BC conditions) then be sure you define enough time steps per periode, 5 as absolute mnimum 10 or more is better (it all depends on the time you ant to wait for the solution ...
Thne you can also consider a gen-alpha, in case of converging issues
Hi indeed it looks like the time stepping is being too coarse, the thing is that by default COMSOL assumes a diffusion type model decay, so when you have a periodic BC you must tweak a little the time stepping settings. Use rather an intermediate or a strict time stepping (and not the default automatic for periodic BC conditions) then be sure you define enough time steps per periode, 5 as absolute mnimum 10 or more is better (it all depends on the time you ant to wait for the solution ... Thne you can also consider a gen-alpha, in case of converging issues -- Good luck Ivar
Posted: 1 decade ago 18 févr. 2013, 14:48 UTC−5
Dear Arka;
I have the same problem as you. I want to define a SIN Temperature for the comsol but i can not define it very well. Would you please help me and tell me that how did you define a Time dependant heat for the software?
Best Regards
Dear Arka; I have the same problem as you. I want to define a SIN Temperature for the comsol but i can not define it very well. Would you please help me and tell me that how did you define a Time dependant heat for the software? Best Regards
Posted: 8 years ago 3 nov. 2016, 08:05 UTC−4
I have a similar problem. I have to set my convective heat flux depending how much time as passed.
For example;
Time (s) 0-500 set h=10
Time 501-1000 set h=20
Time 1001-1500 set h=35
Time 1501-2000 set h=15
How do I covert this into a IF statement to insert into the "Convective heat flux" field ?
Hi, I have a similar problem. I have to set my convective heat flux depending how much time as passed. For example; Time (s) 0-500 set h=10 Time 501-1000 set h=20 Time 1001-1500 set h=35 Time 1501-2000 set h=15 How do I covert this into a IF statement to insert into the "Convective heat flux" field ? Thanks,
Posted: 8 years ago 3 nov. 2016, 08:32 UTC−4
Make a piecewise function, say pw1, and call it then pw1(t). See attachment.
Lasse
Hi Make a piecewise function, say pw1, and call it then pw1(t). See attachment. Lasse
Posted: 8 years ago 3 nov. 2016, 11:51 UTC−4
Thank you,
I have done the piecewise function, but how are you plotting that graph with h as a function of t?
When I plot the graph I don't get any labels at all.
Thank you,
Lasse
Thank you, I have done the piecewise function, but how are you plotting that graph with h as a function of t? When I plot the graph I don't get any labels at all. Thank you, [QUOTE] Hi Make a piecewise function, say pw1, and call it then pw1(t). See attachment. Lasse [/QUOTE]
Posted: 8 years ago 3 nov. 2016, 17:30 UTC−4
The function set-up window (my attachment) asks for the units of the argument and the function. You must fill in them properly.
Posted: 8 years ago 5 nov. 2016, 17:34 UTC−4
Ok, I got it now, thanks for all the help.
