douts in comsol 4.3 version
Karuppasamy Periyasamy
Dear Sir,
Iam using comsol 4.3 version for pipeline inspection modelling (3D), We have one doubt , we would like to move the coil from one place to another place by step by step,Is it possible to move the coil automatically?If it is possible , please tell the procedure to move the coil from one place to another place with in the tube.
Thanking you sir
1 Reply Last Post 10 sept. 2012, 07:58 UTC−4
Posted: 1 decade ago 10 sept. 2012, 07:58 UTC−4
if the "coil" you refer to is the geoemtry loop, yeas with an external Paramatric sweep node (add manually) you can change the geoemtry, but try to keep the topology similar
Hi if the "coil" you refer to is the geoemtry loop, yeas with an external Paramatric sweep node (add manually) you can change the geoemtry, but try to keep the topology similar -- Good luck Ivar
