Drag Force on Moving Sphere with Slip
Posted 7 sept. 2012, 17:49 UTC−4 Fluid & Heat Version 4.2a 0 Replies
sphere is much lower than that of the fluid in the channel. I wanted to use the Creeping Flow module as I did for the hard sphere case, with the spheres having a Slip boundary condition, but there is no way to have one
sphere translating while also having a slip boundary condition. Setting the b.c. to Slip Velocity gives me a drag result that is only ~10% less than the no-slip case, which is not correct according to the theory. Could
you please advise me what approach to take to model droplets in fluid as perfect slip?
Hello Thomas Leary
