Gunnar Andersson
COMSOL Employee
3 years ago
7 oct. 2022, 10:00 UTC+2
There isn't any support for blending. The closest effect that I can think of is to displace one of the slice plots (using a Deformation or Translation subnode) and to enable transparency.
Jeff Hiller
COMSOL Employee
3 years ago
7 oct. 2022, 15:15 UTC+2
Maybe you could use 2 isolevels, one for each quantity, with different color schemes?
Jeff Hiller
3 years ago
11 oct. 2022, 09:13 UTC+2
Thank you for your responses. With the isolevel I was able to see the 2 plots, but I want the slice in a 3D plot group, so the isolevel wouldn't work. I also tried the translation but it moves the entire geomery instead of just the parameter I am plotting. I couldn't figure out how to make the deformation to work.
To make it more clear, the parameter I am plotting is an input heat source.
Jeff Hiller
COMSOL Employee
3 years ago
11 oct. 2022, 15:51 UTC+2
Updated:
3 years ago
11 oct. 2022, 15:52 UTC+2
Hello Edidiong,
See the attached file: I use two contour plots (with different color schemes) defined on Cut Plane 1, which is a data set I added. You can play with the "Contour Type" settings to make each contour plot more to your liking. Here I am using "Filled" and "Tubes", but you can also choose "Lines" (that's the default).
Jeff Hiller
Hello Edidiong,
