Where is the Curl operator in the PDE physics?
I tried to modify the PDE from the rotating machinery physics a little and wanted to define it in the PDE physic.
The problem I have is that I can't see any curl operators in the coeficient or the general form. The original equations are:
sigma* dA/dt + curl(H) - sigma v x B = J
and
B= curl(A)
I'm sure there is a way to define both equations. Maybe I could use the diveregence operator with a matrix or something else...
Thanks in advance
3 Replies Last Post 2 sept. 2012, 08:21 UTC−4
Posted: 1 decade ago 1 sept. 2012, 08:57 UTC−4
In COMSOL vectorial PDE's cannot be input directly. You need to rewrite it as several scalar PDE's, where you will not have curl operator.
Hi, In COMSOL vectorial PDE's cannot be input directly. You need to rewrite it as several scalar PDE's, where you will not have curl operator.
Posted: 1 decade ago 1 sept. 2012, 13:40 UTC−4
Thank you very much for the answer.
I guess this is something that could be improved/added in the future?
Thank you very much for the answer. I guess this is something that could be improved/added in the future?
Posted: 1 decade ago 2 sept. 2012, 08:21 UTC−4
You can also see that by toggling on 'equation view' in the options to the right of the model builder. Then, you can see the equations, and with any one that has a curl operator you will see how it is described.
