Magnus Ringh
COMSOL Employee
3 years ago
31 mai 2022, 09:16 UTC−4
Hi Carl,
To compute an entire study, press F8
. To compute a selected study step, press F7
. Currently there is no shortcut key for canceling a solution process, but we will look into that for a future version. For now, you can use the Cancel button in the lower-right corner of the COMSOL Desktop or any of the Stop buttons in the Progress window.
Magnus
Hi Carl,
To compute an entire study, press `F8`. To compute a selected study step, press `F7`. Currently there is no shortcut key for canceling a solution process, but we will look into that for a future version. For now, you can use the **Cancel** button in the lower-right corner of the COMSOL Desktop or any of the **Stop** buttons in the **Progress** window.
Magnus
Edgar J. Kaiser
Certified Consultant
3 years ago
31 mai 2022, 13:39 UTC−4
Hi Carl, Magnus,
it should be added that by using the 'cancel' button you typically loose the so far calculated solution, e.g. in a time dependent study. Using the 'stop' buttons preserves the solution.
In an application there is no option to 'stop' the solution in a controlled way, you always loose the complete solution by cancelling.
@Magnus: is anything in view to allow a controlled stop in applications?
Cheers
Edgar
Edgar J. Kaiser
emPhys Physical Technology
www.emphys.com
Hi Carl, Magnus,
Cheers
Edgar
3 years ago
2 juin 2022, 23:39 UTC−4
Hi Magnus, Edgar,
thanks so much for your help! Once a solution is stopped (a) and continued (b), probe plots during (a) disappear. Is there a solution to this?
Hi Magnus, Edgar,
