Non Isothermal - Continuous casting problem(ERROR)
Posted 9 août 2012, 11:49 UTC+2 0 Replies
I was trying to model a 3D square billet analysis using the non isothermal flow.
Initially I had multiple errors immediately after I computed. Now, after a long time of run I get following error,
Failed to find a solution.
Divergence of the linear iterations.
I tried Meshing from fine to coarse but still it takes longer time and gives the above error at the end. I guess the Boundary conditions are good. I followed the model library example for continuous casting.
Please let me know your suggestions.
If anyone knows how to model for square billet continuous casting problem, please share your knowledge.
Thank you very much.
Hello Kailash BVM
