How to get temperature standard deviation?
After obtaining the temperature field, only the maximum, minimum and average values of the temperature of a certain surface can be obtained, and the temperature standard deviation can not be obtained. How to get temperature standard deviation?
2 Replies Last Post 10 mai 2022, 22:52 UTC−4
Posted: 3 years ago 11 avr. 2022, 08:41 UTC−4
Updated: 2 days ago 18 avr. 2025, 09:09 UTC−4
You can compute a standard deviation using average coupling operators: one to compute the average of the temperature, and then one to compute the standard deviation itself now that you have the average.
In versions of the software that predate the average coupling operator, you can achieve the same via the use of integration coupling operators (since the volume can be computed by integrating 1).
Jeff Hiller
You can compute a standard deviation using average coupling operators: one to compute the average of the temperature, and then one to compute the standard deviation itself now that you have the average. Best, Jeff In versions of the software that predate the average coupling operator, you can achieve the same via the use of integration coupling operators (since the volume can be computed by integrating 1).
Posted: 3 years ago 10 mai 2022, 22:52 UTC−4
Updated: 2 days ago 18 avr. 2025, 09:10 UTC−4
Thank you!
Thank you!
Reply
