error graph
Divyaniben Ramanlal Prajapati
How to draw error graph in comsol?
1 Reply Last Post 31 mars 2022, 16:40 UTC−4
Posted: 3 years ago 31 mars 2022, 16:40 UTC−4
Hello Divyaniben Ramanlal,
I assume that you are trying to plot the difference between a/ the result of the COMSOL computation and b/ an analytical solution you have derived. If so, you can modify any plot to subtract from the expression that's plotted an analytical expression of your choice: simply edit the expression field for the plot in question.
Jeff Hiller
Hello Divyaniben Ramanlal, I assume that you are trying to plot the difference between a/ the result of the COMSOL computation and b/ an analytical solution you have derived. If so, you can modify any plot to subtract from the expression that's plotted an analytical expression of your choice: simply edit the expression field for the plot in question. Best regards, Jeff
