How to obtain self inductance and mutual inductance of conductors
Posted 25 mars 2022, 06:55 UTC−4 Low-Frequency Electromagnetics Version 6.0 0 Replies
two or more conductors ( not in coil shape) or one conductor with more than two terminals, how to obtain their self inductance of conductors and mutual inductance between every two conductors or terminals.
First, which Physics interface(s) should be used, mfco(Magnetic Fields Current Only , mf ( Magnetic Fields ) or mef ( Magnetic and electric fields ). And frequency domain study should be added.
Second, If mfco is chosen, one conductor can only add one terminal. So if one conductor with one terminal which current flows in and two or more terminals which current flows out, how does it work? If mf is chosen, how can current be added to the face? And how to calculate the inductances? If mef is chosen, there is similar questions with the mf physics interface.
Third, the mcfo can calculate the inductance matrix directly, but the other two physics interface cannot obtain the matrix. Inductance can be calculated by definition formula of inductance. But the calculated number is just a real or complex number. Does the effect of mutual inductances contain in the number? How can I obtain the mutual inductance? Using the formula ?
I‘ve been confused these for a long time. I hope deeply someone can help me
Thank you very much.
Hello 剑波 周
