Adding data sets to Cut Points
Hello, I am trying to plot the data from my simulation (time vs temp) and when I add the cut point and try to select a data set, the only option is "none" when I need the data set from my solution. Any idea why my cutpoint has no data set options?
2 Replies Last Post 9 mars 2022, 13:52 UTC−5
Magnus Ringh COMSOL Employee
Posted: 3 years ago 9 mars 2022, 05:34 UTC−5
It could be because the Cut Point dataset's dimensions don't match the Solution dataset's dimensions. For a 3D solution, for example, you need to use a Cut Point 3D dataset (unless you have some other dataset that has converted the 3D solution to a plane, for example; then you can use a Cut Point 3D dataset with the Cut Plane dataset as the input).
Magnus
Hi, It could be because the Cut Point dataset's dimensions don't match the Solution dataset's dimensions. For a 3D solution, for example, you need to use a Cut Point 3D dataset (unless you have some other dataset that has converted the 3D solution to a plane, for example; then you can use a Cut Point 3D dataset with the Cut Plane dataset as the input). Best regards, Magnus
Posted: 3 years ago 9 mars 2022, 13:52 UTC−5
Hello Mya,
One possibility is that your model is 2D and you are trying to create a "Cut Point 3D" dataset, or vice versa.
Jeff Hiller
Hello Mya, One possibility is that your model is 2D and you are trying to create a "Cut Point 3D" dataset, or vice versa. Best, Jeff
