Error Correction in COMSOL Document
In "Heat Transfer Module > User's Guide > Theory for the Heat Transfer Module > Theory for Thermal Contact", the relative pressure p ⁄ Hc calculated by the follwing equation is from the Ref.1.
P/Hc=(P/(c1(1.62sigma/sigma0m)^c2))^(1/(1+0.071c2)); 1. A. Bejan and others, Heat Transfer Handbook, John Wiley & Sons, 2003.
However, in many other papers, containing the reference of the wrong equation in Ref.1, p ⁄ Hc using the following equation instead. The difference with the above one is its math symbol before the variable m.
P/Hc=(P/(c1(1.62sigma/sigma0/m)^c2))^(1/(1+0.071c2)); *2. S. Song and others, Relative Contact Pressure: Dependence on Surface Roughness and Vickers Microhardness, Journal of thermophysics and heat transfer, 1988. 3. M. Bahrami and others. Modeling Thermal Contact Resistance: A Scale Anslysis Approach, J. Heat Transfer, 2004.
I am not sure if it has other influence in Comsol, though any impacts has not had on CMY conductance model in my limited simulation.
1 Reply Last Post 7 mars 2022, 07:36 UTC−5
Anthony Paumier COMSOL Employee
Posted: 3 years ago 7 mars 2022, 07:36 UTC−5
Dear 程万里 鹏,
Thank you for posting on the Discussion Forum. You are right, there is a mistake in our documentation. I want to emphasize that the equations are solved using the correct formula: as you wrote it, so there is no worries to have about the results.
Thank you for pointing out this mistake, we have corrected the documentation.
Anthony Paumier
Dear 程万里 鹏, Thank you for posting on the Discussion Forum. You are right, there is a mistake in our documentation. I want to emphasize that the equations are solved using the correct formula: \frac{p}{H_c} = \left(\frac{p}{c_1 \left(1.62 \frac{\sigma_\textrm{asp}}{m_\textrm{asp} \sigma_0} \right)^{c_2}} \right)^\frac{1}{1+0.071 c_2} as you wrote it, so there is no worries to have about the results. Thank you for pointing out this mistake, we have corrected the documentation. Best regards, Anthony Paumier
