Heat Transfer Boundary Condition Error
Posted 9 févr. 2022, 20:30 UTC−5 Heat Transfer Version 5.5 0 Replies
I am trying to simulate a simple 3D heat transfer problem with surface to surface radiation. I have set a constant temperature at the bottom of the cylinder and periodic boundary conditions on the side of the cylinder. However, as I try to run the study I get the error:
"Periodic condition does not support curved boundaries when using the automatic detection of orientation - Selection: 1 - Variable: map.item.dflux"
Thank you for your help
Hello Vincenzo Costanza
