Constraint the sum of two variables
I am working on a problem with two dependent variables, and I have two PDEs to update these variables, respectively. Each variable should be between 0 and 1, and I constrain them via setting upper and lower limits in COMSOL. In addition, I also need to constrain the summation of these two variables smaller than 1, but I did not find a way to do this in COMSOL. Could anyone give me some tips about this?
2 Replies Last Post 24 févr. 2022, 05:43 UTC−5
Posted: 3 years ago 8 févr. 2022, 02:44 UTC−5
Can't you define a new variable as the sum of the two, and use that subsequently?
René Christensen, PhD
Acculution ApS
www.acculution.com
info@acculution.com
Posted: 3 years ago 24 févr. 2022, 05:43 UTC−5
Thanks for your suggestion, Rene. I will try to implement this.
>Can't you define a new variable as the sum of the two, and use that subsequently? Thanks for your suggestion, Rene. I will try to implement this.
