Measurements of conductivity in graphene
Hi all,
I'm studying the conductivity of a graphene-based device depending on the gate voltage applied on it. The thing is, to perform the simulation, Comsol requires a value for the conductivity, which is precisely the thing I want it to calculate.
Any suggestions ?
Thanks by advance.
2 Replies Last Post 23 juin 2016, 01:48 UTC−4
Hello Julien Paparone
Posted: 9 years ago 22 juin 2016, 01:17 UTC−4
As far as I know, material library of COMSOL does not provide graphene physical model. You need to calculate it numerically using either simple Drude model or more sophisticated Kubo formulation.
Posted: 9 years ago 23 juin 2016, 01:48 UTC−4
If you treat it as a semiconductor you'd need a carrier mobility, not a conductivity. You should be able to model it as a semiconductor.
