Application of Porous Media in Turbulent flow
余 满 多孔介质干燥领域
Hello everyone, I am doing a model of porous media evaporation in turbulence. I want to set the external flow field as k – ε flow, but if set in this way, the basic properties of fluid in porous media cannot be obtained. I tried that the external flow field was y + flow and the calculation converged.So I would like to ask how to set up the interface to obtain the external flow field and the internal multi-physics field when the porous medium is calculated in other types of turbulent flows.
Thank you.
0 Replies Last Post 26 nov. 2021, 02:39 UTC−5
Hello 余 满
