Propagation of acoustiс wave in solid
Михаил Александрович Филиппов
Hello. I want to simulate propagation and reflection ultrasound wave induced by piezodisk. Piezodisk is located in epoxy compaund. Wave propagate through compaund and reflect from steel plate. I use Solid Mechanics from Elastic Waves and multiphysics Piezoelectric Devices. The single Gaussian Signal is applied to the piezodisk. I use Time Dependent Study. How to correctly define the connections between different solid materials in this case, especially between steel plate and compaund? And can I use the module Elastic Waves with Piezoelectric Effect with time-dependent signal?
2 Replies Last Post 16 déc. 2021, 13:37 UTC−5
Posted: 3 years ago 16 déc. 2021, 03:40 UTC−5
Privet. I don't have the piezoelectric module, but isn't he coupling between the different domains available under the Multiphysics node?
René Christensen, PhD
Acculution ApS
www.acculution.com
info@acculution.com
Posted: 3 years ago 16 déc. 2021, 13:37 UTC−5
It seems you are doing it all in solid mechanics. In this case you don't need specific boundary conditions between the domains. You finalize the geometry into a union and Comsol is taking care of the continuity. You can do a time dependent study with piezoelectric domains.
Cheers Edgar
Edgar J. Kaiser
emPhys Physical Technology
www.emphys.com
It seems you are doing it all in solid mechanics. In this case you don't need specific boundary conditions between the domains. You finalize the geometry into a union and Comsol is taking care of the continuity. You can do a time dependent study with piezoelectric domains. Cheers Edgar
