Electric field at a specific point in Geometry
[start here] Hey, I was trying to plot the electric field at a specific point in my cylindrical geometry. Eventhough I created the dataset of cutpoint, this data set is not showing in the data set list while plotting the 1D line plot. How can I overcome this?
1 Reply Last Post 9 nov. 2021, 09:35 UTC−5
Posted: 3 years ago 9 nov. 2021, 09:35 UTC−5
Don't use a line plot. Use a point plot. And select the Cutpoint as your dataset. I suggest that you work through some of the Comsol-supplied tutorials and other example files to become more familiar with the post-processing plotting options available to you.
Don't use a *line* plot. Use a *point* plot. And select the Cutpoint as your dataset. I suggest that you work through some of the Comsol-supplied tutorials and other example files to become more familiar with the post-processing plotting options available to you.
