Plotting Temperature Gradient Vs distance ( path of nodes )
Posted 1 nov. 2021, 13:32 UTC−4 Heat Transfer & Phase Change, Results & Visualization Version 5.6 0 Replies
I would like to plot a graph with the Temperature Vs the Depth z in mm ==> Temperature gradient along a predefined path. The path should across different nodes from the Meshed geometry. is it possible on comsol ? Thank you
Hello Haifa SALLEM
