Value on a given point of the mesh
Hello everybody,
I am a newbie in Comsol, and I am looking for a vizualisation function. I have a model for the electric field gradient between an active electrode and a ground electrode. To do so, I have a 2D Plot on the x and z axis, in order to know the electric field intensity near my electrodes (between them and in height).
I want to know the value of the electric field intensity in a point. I know that you can click on the interested point to have the value.
But in fact I want to obtain the value on an accurate point (so you can't be very accurate by just cliking on the area), and also for several points (~10).
Is there a solution to ask Comsol to calculate the value of the electric field intensity on several points, for example, in entering the coordinates ?
Thank you very much for your help, and if you can detail the procedure, it will be great ! ;-)
1 Reply Last Post 29 juin 2012, 10:34 UTC−4
Posted: 1 decade ago 29 juin 2012, 10:34 UTC−4
Look up the functionalities of the Results - Data-Set right click options: Cut line(s) or cut point(s)
Hi Look up the functionalities of the Results - Data-Set right click options: Cut line(s) or cut point(s) -- Good luck Ivar
