Inverse heat transfer problem
I need to determine the surface temperature by doing an inverse heat transfer problem method.
Experiments are done with impingement of a hot steel plate(900°C) with 3 thermocouples located at 1mm below the surface. The data is measured at a rate of 150Hz. This gives a nice temperature/time dependence at these locations.
Is is possible in COMSOL4.2a to load these data sets from the thermocouples into COMSOL to perform a inverse heat transfer problem to calculate surface temperatures/heat fluxes?
Regards
5 Replies Last Post 3 févr. 2015, 01:13 UTC−5
Posted: 1 decade ago 25 juin 2012, 18:14 UTC−4
What are the unknowns in the heat transfer model that you want to calculate as the inverse problem?
Posted: 1 decade ago 25 juin 2012, 18:27 UTC−4
The temperature and the heatflux at the surface. And the program should use datasets from the thermocouples.
[QUOTE] What are the unknowns in the heat transfer model that you want to calculate as the inverse problem? [/QUOTE] The temperature and the heatflux at the surface. And the program should use datasets from the thermocouples.
Posted: 1 decade ago 26 juin 2012, 01:59 UTC−4
yes you can drive the input power flux (as an average value, not a distributed field though) by making an error function from the difference of the sum_over_"i"_of(T_measured_i_ - T_at_sensor_i)^2 and define it in a weak expression node
back in 3.5 I believe there was a thermal example in the model library using one side to drive the inlet on the other, but I cant find it back in my 4.3
Hi yes you can drive the input power flux (as an average value, not a distributed field though) by making an error function from the difference of the sum_over_"i"_of(T_measured_i_ - T_at_sensor_i)^2 and define it in a weak expression node back in 3.5 I believe there was a thermal example in the model library using one side to drive the inlet on the other, but I cant find it back in my 4.3 -- Good luck Ivar
Posted: 1 decade ago 28 févr. 2013, 05:41 UTC−5
Hello!!
Question for Ruben Brink?
I have exactly the same problem as you!
question:
Whether we can exchange e-mail?
Sefik Behrem
Hello!! Question for Ruben Brink? I have exactly the same problem as you! question: Whether we can exchange e-mail? Sefik Behrem
Posted: 1 decade ago 3 févr. 2015, 01:13 UTC−5
I am having the same problem. Can you share your email id so that we can have a personalised talk regarding the same. My email id is sanchitsingal84@gmail.com
Regards
Sanchit Singal
IIT Kharagpur, India
I am having the same problem. Can you share your email id so that we can have a personalised talk regarding the same. My email id is sanchitsingal84@gmail.com Regards Sanchit Singal IIT Kharagpur, India
