Two phase flow moving mesh + Electrostatics
Posted 21 juin 2012, 08:26 UTC−4 Low-Frequency Electromagnetics, Computational Fluid Dynamics (CFD) Version 4.2, Version 4.2a 2 Replies
I am trying to model a contact angle change by maxwell stress tensor using the moving mesh module coupled with the electrostatic (from where the electric field is calculated).
The modules work fine taken separately, but when coupled with the body force, or even without coupling but solved at the same time, the contact angle doesn't change, in fact the system doesn't converge.
Can you tell me if there is any problem in this coupling?
VdV
VdV
2 Replies Last Post 8 mars 2013, 22:10 UTC−5
