Plasma simulation error - cannot calculate denomMn
Posted 17 août 2021, 20:15 UTC+2 Low-Frequency Electromagnetics, Plasma Physics, Fluid & Heat Version 5.6 0 Replies
I am trying to simulate ICP plasma in a chamber with continuous gas inflow (and outflow). The chmaber itself is maintained at low pressure (0.025 Torr), but the inlet flow rate is specified using mass flow boundary condition at 1 atm pressure.
I am using the plasma, magnetic fields module and laminar flow module (to model the fluid flow).
I am encountering the following error:
Division by zero. Function: / Failed to evaluate variable. Variable: comp1.plas.Mn, Defined as: 1/comp1.plas.denomMn
Any suggestions on how to resolve this?
Hello Anamika Chowdhury
