Livelink for AutoCAD
I'm using Comsol 4.2a and AutoCad 2010. When I connect them via LiveLink to import 3D geometry, comsol shows me:
"Failed to connect to AutoCAD. Please make sure AutoCAD is running."
I am using Windows 7.
Can anybody help me in this, please?
Thanks in advance.
Bashar
4 Replies Last Post 24 juin 2012, 10:09 UTC−4
Posted: 1 decade ago 14 juin 2012, 05:18 UTC−4
Anybody can help PLEASE!
Posted: 1 decade ago 14 juin 2012, 05:42 UTC−4
I do not know if it can be useful...
I also use Windows 7.
You need to have AutoCAD running and open the project to be imported, and then you synchronize Comsol.
I hope to help you!
Chiara
Hi, I do not know if it can be useful... I also use Windows 7. You need to have AutoCAD running and open the project to be imported, and then you synchronize Comsol. I hope to help you! Chiara
Posted: 1 decade ago 14 juin 2012, 06:31 UTC−4
Hi Chiara
Thanks for your reply. Actually, I already did that, but it keeps giving me this error message:
I dont know where is the problem!
Hi Chiara Thanks for your reply. Actually, I already did that, but it keeps giving me this error message: "Failed to connect to AutoCAD. Please make sure AutoCAD is running." I dont know where is the problem!
Posted: 1 decade ago 24 juin 2012, 10:09 UTC−4
Solution from COMSOL knowledge support:
"AutoCAD LT does not support third party add-ins. To use the LiveLink interface you need the standard AutoCAD version."
Hope this helps.
Cheers.
Solution from COMSOL knowledge support: "AutoCAD LT does not support third party add-ins. To use the LiveLink interface you need the standard AutoCAD version." Hope this helps. Cheers.
